It is currently Thu Aug 21, 2025 4:50 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
PostPosted: Wed Aug 21, 2013 8:24 am
I got my order of fish glue about a month ago and just got around to trying it. Just like I said when I started using HHG, I wish I had tried it sooner. It is great to work with, cleans up easily, and the smell is not as bad as I had imagined. It will be great in several situations where HHG is difficult to use.
Thanks to to all the folks on this board for sharing their information and giving me the bump I needed to give it a try.
James
PostPosted: Wed Aug 21, 2013 9:55 am
First name: Rusty
Filippo, do you refrigerate fish glue or will it last several years on the shelf?
Sent from my iPhone using Tapatalk 2
PostPosted: Wed Aug 21, 2013 12:05 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
go to
www.norlandprod.com/fishgel/hightack.html
Mike Collins
PostPosted: Wed Aug 21, 2013 12:49 pm
Last Name: Ensor
City: Springfield
State: Missouri
What applications are people using fish for? I mainly use it for binding but would love to hear where others are implementing it.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Wed Aug 21, 2013 1:10 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
uke fb, bridges, binding /purfling ,headstock veneer front and rear gives assembly time instead of using dowel pin locators, bracing, repairs. I used a 250 deg omega heater to see if it can remove a fb , didn/t budge .This fish glue from LV is tough.I froze 1/2
PostPosted: Wed Aug 21, 2013 2:00 pm
Like Filippo, I use it for everything except braces and occassionally bridges. Haven't had any problems so far.
Sent from my GT-I9100M using Tapatalk 2
Under Compensated Nut!
PostPosted: Wed Aug 21, 2013 5:01 pm
I like it for re-installing the tops or backs on a restoration. I had trouble using HHG in this application. The fish glue is great for this since it has a longer open time to position everything.
I like HHG for braces on a new top. I am able to work fast enough with the go-bars to get the braces where I want them for the short open time on HHG. I'll use the fish glue for re-gluing existing braces on a repair.
I will try the fish glue on my next binding and see how that goes.
James
PostPosted: Wed Aug 21, 2013 6:17 pm
First name: Tim
Last Name: Allen
City: San Francisco
I use it for almost everything except gluing fretboards. As a relative beginner, I really appreciate the slow set time. I don't have to hurry setting up clamps or go-bars, and if things start to slip a little under pressure I have time to correct it.
Tim Allen
"Never hurry, never rest."
PostPosted: Wed Aug 21, 2013 7:16 pm
I use it for every joint. I've been using epoxy for fretboard to neck but the last one I did fish glue and its just fine.
PostPosted: Wed Aug 21, 2013 9:24 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Same - I've used it on every joint for the past 10 builds - love it!
PostPosted: Thu Aug 22, 2013 12:06 am
Last Name: Shanklin
City: Windsor
State: ON
I even use it for repairing 100+ year old baseboards, and door & window trim.
Bob
PostPosted: Thu Aug 22, 2013 7:10 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I wish LMI carried fish glue. I know Lee Valley has it but I rarely order from them so I never get them...
Typhoon Guitars
PostPosted: Thu Aug 22, 2013 7:18 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
anyone in UK recomend a supplier?
We are all in the gutter but some of us are looking at guitars.
PostPosted: Thu Aug 22, 2013 7:52 am
I've not seen it sold in the UK. I get it from Kremer Pigmente. I prefer HHG for virtually everything, apart from laminating backs and end grain to end grain joints.
PostPosted: Thu Aug 22, 2013 8:27 am
First name: David
Last Name: LaPlante
I use fish glue for everything with the exception of Titebond for:
-Laminating heels (1 joint)
-Joining tops (Titebond is a bit less visible according to Romanillos)
-gluing fret board (less moisture in Titebond I think)
PostPosted: Thu Aug 22, 2013 9:59 am
First name: David
Last Name: LaPlante
Well, This is a statement he made at the 2007 course in Siguenza. I had always used Titebond to join tops up till that time so I simply continued. I've never done any experimentation to confirm or deny this.
My impression on moisture (and the percentage of solids to water in the glue) is based on the fact that Titebond gets very snotty very quickly (much more so than Fish) so even if the moisture content is similar I think perhaps less of it gets into the wood itself which is of course what everyone is trying to avoid.
PostPosted: Thu Aug 22, 2013 4:29 pm
First name: Mark
Last Name: Parkinson
Country: South Wales, UK
I used rabbit skin glue (RSG) for the first time today, not on a guitar, just practicing with it
It's quite satisfying making it up and using it, a little different to getting glue straight out of the bottle
I don't know what the benefits and disadvantages of RSG are though - can anyone enlighten me?
is it possible to dehydrate hide glue?
PostPosted: Thu Aug 22, 2013 10:35 pm
If anyone in Seattle wants to try some, I am selling some from Lee Valley over in the classifieds. BYOB
I am only using it on bindings & I love it. I bought the giant 34 oz bottle to save on shipping, but I think half that will last me a long time.
PostPosted: Fri Aug 23, 2013 3:08 am
Last Name: Thomas
City: Hobart
State: Tasmania
One great advantage of HHG is that it is relatively easy to separate a joint without damage. Does fish glue share this advantage?
PostPosted: Fri Aug 23, 2013 3:53 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I heard fish has the same advantage of hide glue and long open time. I do agree it's easy to separate hide glue, especially if the joint is old. Often all it took in that case was a knife in the joint and they would pop free without damage. Heat isn't needed either. Do have to be more careful and use heat with fresher hide glue joint however, it is not as brittle.
Typhoon Guitars
PostPosted: Fri Aug 23, 2013 6:23 am
Fish Glue seems to be harder to pull apart, at least it does on the few bits that I've tried to disassemble. I suppose that depends on the HHG as well. There's an awful lot of variation in HHG, not much in Fish glue though.
PostPosted: Mon Aug 26, 2013 8:58 am
Cheapest I could find here http://shop.apfitzpatrick.co.uk/63550-kremer-fish-glue-liquid-250ml-1578-p.asp
PostPosted: Fri Aug 30, 2013 9:27 am
First name: Lee
Last Name: Passmoor
City: Newport Pagnell
State: Bucks
Zip/Postal Code: MK16 8JG
Country: United Kingdom
Well, after all this fish glue talk I decided I should give it a go, so just received this in the post today!
It didn't come with any storage recommendations, so what is best? Kept in fridge? Avoid too much cold?
PostPosted: Fri Aug 30, 2013 9:49 am
First name: David
Last Name: LaPlante
Long term I'll keep in the fridge........normal term (several years +) room temp seems fine.
I'm just finishing up now glue I bought 5 years ago........
PostPosted: Fri Aug 30, 2013 10:24 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I guess it's different depending on what fish it came from... I wonder if you could use Catfish glue and then string the guitar with Catgut string, so it goes MEEEOOOWW when you pluck it.
Typhoon Guitars
These users thanked the author Tai Fu for the post: George L (Fri Aug 30, 2013 1:12 pm)
Users browsing this forum: doncaparker and 14 guests
